Текущее время: 08 сен 2025, 17:22
Начать новую тему Ответить на тему  [ Сообщений: 30 ]  На страницу Пред.  1, 2, 3
СообщениеДобавлено: 24 сен 2012, 12:14
Home > What is Toyota TPMS? > Components of the Direct Toyota TPMS System
The system is fitted to the following vehicles in line with NHTSA requirements: 4 Runner (2005-9), Avalon (2006-9), Camry (2007-9), Corolla (2007-9), FJ Cruiser (2009), Highlander (2007-9), Land Cruiser (2005-9), Matrix (2007-9), Prius (2007-9), RAV4 (2006-9), Sequoia (2005-9), Sienna (2007-9), Solara (2006-9), Tacoma (2005-9), Tundra (2005-9), and Yaris (2007-9). It comprises the following components on Toyota vehicles:
A direct TPM sensor fitted to the back of the valve stem on each wheel.
A TPM Warning Light
A Tire Pressure Monitor ECU
Antenna(s)
The manufacturers of the Toyota TPMS are TRW Automotive and Pacific Industrial Corp.
Indirect Toyota TPMS
Toyota vehicles Sienna (pre-2006), Camry Solara (2004-6), Highlander (2004-7), Corolla (2005-7), and Matrix (2005-7) used an indirect or ABS type TPMS. This system uses the existing wheel speed sensors in the antilock brake system (ABS). The system monitors tire pressures by comparing relative wheel speeds. As the pressure in a tire falls the diameter of the tire reduces causing it to turn faster than the other wheels on the car. This difference can be seen by the wheel speed sensors and communicated to the skid control ECU. These systems require the relearning of the rotational parameters of each tire when the tires are replaced, rotated or repaired. Toyota have fitted a TPMS Reset switch for this purpose.
Вот что то примерно так.....
ссылка
http://www.toyotatpms.com/toyota-tpms-components.html
Последний раз редактировалось bus 24 сен 2012, 12:15, всего редактировалось 1 раз.
СообщениеДобавлено: 24 сен 2012, 12:28
У тебя такие нипеля-датчики?[attachment=3780:1.JPG]
1.JPG [99.79 КБ]
СообщениеДобавлено: 24 сен 2012, 13:05
Они самые! Надо их прописывать?
Последний раз редактировалось bus 24 сен 2012, 13:07, всего редактировалось 1 раз.
СообщениеДобавлено: 24 сен 2012, 13:08
Да, такие надо прописівать. Я еще не сталкивался с тем, что такие датчики на Соларах стоят. Но по программе ставились. Век живи, век учись...
ПІ.Сі. Пардон, за украинский.
СообщениеДобавлено: 24 сен 2012, 13:11
А для этого чего надо? и у меня зимняя резина и летняя на разных дисках и с разными соответственно датчиками, мне теперь раз в полгода на прописку?
СообщениеДобавлено: 24 сен 2012, 13:13
Дай мне времени, до конца недели. Я узнаю, может можно все сразу датчики в блок прописать и с летних дисков и с зимних.
СообщениеДобавлено: 27 сен 2012, 18:36
а кто знает назначение лампочки слева от лампочки непристегнутого ремня. изображена машинка с горящими задними фонарями,цвет желтый.
завел,загорелась,через 2 минуты потухла. Сколько ездил,такого обозначения не разу не видел, иллюминация сзади вся работает без проблем.
СообщениеДобавлено: 27 сен 2012, 21:43
Ответ прост! ag.gif Не горела одна из стоп лампочек. Это ее индикатор. Ты поехал и при торможении нить качнулась и слиплась (восстановилась). Вот ошибка и пропала. ce.gif
СообщениеДобавлено: 28 сен 2012, 13:13
Игорь прав. У тебя горела лампа индексации неисправности ламп стоп-сигналов.
СообщениеДобавлено: 29 сен 2012, 22:25
Герман писал(а):
Цитата(Герман @ 12.9.2012, 4:13) <{POST_SNAPBACK}>
На панели приборов загорелась лампочка с восклицательным знаком(не ручник), подскажите пожалуйста, в чем проблема??
Shift the way you drive.
